Command disabled: backlink
Routes
Depending on set flags format of response can differ.
This chapter describes flags that can be applied to routes and parts of resulting JSON which they are responsible for. If you specify several flags, then parts will be gathered into one JSON.
Route flags:
Value Description
0x00000001 base flag
0x00000002 custom properties
0x00000004 billing properties
0x00000040 GUID
0x00000080 administrative fields
0x00000100 configuration
0x00000200 check points
0x00000400 schedules
0x00000800 rounds
0x3FFFFFFFFFFFFFFF set all possible flags to route
General properties
Flag - 0x00000001
	"nm":<text>,	/* name */
	"cls":<uint>,	/* superclass ID: "avl_route" */
	"id":<unit>,	/* route ID */
	"uacl":<unit>	/* current user access level for route */
Custom properties
Flag - 0x00000002
You can store any route data you need in custom properties.
	"prp":{}	/* custom properties */
Billing
Flag - 0x00000004
	"crt":<uint>,	/* creator ID */
	"bact":<unit>	/* account ID */
GUID
Flag - 0x00000040
	"gd":<text>	/* route GUID */
Administrative fields
Flag - 0x00000080
	"aflds":{	/* administrative fields */
		<text>:{	/* sequence number */
			"id":<uint>,	/* ID */
			"n":<text>,	/* name */
			"v":<text>	/* value */
	"afldsmax":<long>,	/* maximal count of administrative fields (-1 - unlimited) */
Configuration
Flag - 0x00000100
	"rcfg":{	/* configuration */
		"color":<long>,		/* color (ARGB) */
		"descr":<text>,		/* description */
		"units":[<long>]	/* array of units IDs */
Check points
Flag - 0x00000200
	"rpts":[	/* check points */
			"f":<uint>,	/* type (see below) */
			"u":<long>,	/* unit ID, 0 - if check point not of type "check point from units" */
			"y":<double>,	/* longitude */
			"x":<double>,	/* latitude */
			"r":<uint>	/* radius, m */
Types of check points:
  • 1 – check point from map or POI;
  • 2 – check point from geofence;
  • 3 – check point from unit.
Schedules
Flag - 0x00000400
	"rs":{	/* list of schedules */
		<text>:{	/* sequence number of schedule */
			"id":<long>,	/* schedule ID */
			"f":<uint>,	/* type */
			"tz":<uint>,	/* time zone */
			"cfg":{		/* custom configuration (example) */
				"autoName":<byte>,	/* use automatically generated name:  0 - no, 1 - yes */
				"enabled":<byte>,	/* auto create rounds for current schedule: 1 - enable, 0 - disable */
				"name":<text>,		/* round name */
				"roundFlags":<uint>,	/* round flags */
				"units":[<long>],	/* array of units IDs */
				"validityPeriod":<uint>	/* validity period */
			"tm":[		/* time of passing points */
					"at":<uint>,	/* arrival time */
					"ad":<uint>,	/* deviation from arrival time */
					"dt":<uint>,	/* departure time */
					"dd":<uint>	/* deviation from departure time */
			"sch":{		/* time limitation */
				"f1":<uint>,	/* beginning of interval 1 */
				"f2":<uint>,	/* beginning of interval 2 */
				"t1":<uint>,	/* ending of interval 1 */
				"t2":<uint>,	/* ending of interval 2 */
				"m":<uint>,	/* days of month mask */
				"y":<uint>,	/* months mask */
				"w":<uint>	/* days of week mask */
Types of schedules are described in the chapter Schedules: create, edit, delete.
Rounds
Flag - 0x00000800
	"rr":{		/* rounds */
		<text>:{	/* sequence number of round */
			"id":<long>,	/* round ID */
			"d":<text>,	/* description */
			"sh":<text>,	/* schedule name */
				"f":<uint>,	/* round flags */
				"u":<long>,	/* unit, assigned on this round: if not specified - first unit of array "cu", which go out from first check point, will be assigned */
				"at":<uint>,	/* activation time */
				"vt":<uint>,	/* time from which validity period begins */
				"vp":<uint>,	/* validity period */
				"sts":<uint>,	/* state flags */
				"st":{		/* round state */
					"st":{		/* general round state */
						"pi":<uint>,	/* check point index, if 4294967295 - round isn't started */
						"ps":<uint>,	/* state flags + event flags (see below) */
						"ut":<uint>	/* last event time */
					"pts":{ 	/* состояние по точкам */
						<text>:{	/* check point ID */
							"st": <uint>,	/* event flags */
							"tm": <uint>	/* last event time */
Values of round, state and event flags are described in the chapter Round information.
Follow us on Facebook Gurtam Wialon info@gurtam.com   |   Copyright © 2002-2025 Gurtam
